Article ID : 00117517 / Last Modified : 28/08/2023Print
Where to find my TV's software version, device ID, model name or serial number?
    Where to find TV System Information
    The steps to access your TV System Information (e.g. software version, device ID, model name or serial number) using the TV menu vary depending on the type of TV you have. Choose your TV type for more details.
    Android TV and Google TV
    If your remote control has a HELP button
    1. On the remote control, press the HELP button.
    2. The next steps will depend on your TV menu options:
      • Select System information in the Status & Diagnostics or Troubleshooting and system information Category.
      • Select Contact & Support.
      • For W8, X7 series: The model name is displayed in the bottom-left part of the screen.
      The screen varies depending on your TV model. The following are examples.
      System information in the menu screen
      System information screen
    If your TV remote control doesn't have a HELP button
    1. Open the  Settings screen.   How to access Settings
      • Select Settings  Help and Feedback  Help  Status & Diagnostics  System information.
      • Select Apps → Help  System information in the Status & Diagnostics or Troubleshooting and system information Category.
      • Select Help  System information in the Troubleshooting and system information Category.
      • Select Settings  BRAVIA Settings  Customer Support → Contact & Support.
    TVs other than Android TV or Google TV
    TVs released in 2015 and later
    1. On the remote control, press the HOME button.
    2. Select Settings.
    3. Select System Settings or Product Support.
    4. Select Customer Support or System Information.
    5. Select Product Information.
      Product Information
    TVs released in 2014
    2. Select (?) Help.
    3. Select Customer Support.
    4. Select System Information.
      System Information
    TVs released in 2013 or before
    2. Select Settings.
    3. Select Product Support or Set-up.
    4. Select System Information or Product Information.
      Product Information and System Information
    Related articles
