The operating system (OS) version differs depending on your TV’s model or the update status of its software.
Check the version by the following steps:
- Press the HOME button on the remote control.
- Select
Settings.
- The next steps will depend on your TV menu options:
- Select Device Preferences — About — Version. (Android 9)
- Select About — Version. (Android 8.0 or earlier)
