Article ID : 00115761 / Last Modified : 07/12/2020Print
Connect your Sony's Android TV to the Internet
    To get the best possible experience from your new Sony's Android TV, after the  setup and installation process, you should then connect your TV to the Internet.
    Connect your Sony Android TV
    In this section, you will find frequently asked questions (FAQs) on how to connect your device to the Internet.
    To find out how to use your Sony's Android TV's smart features and other basic functions, go to the Use your TV page.
