Article ID : 00113538 / Last Modified : 07/12/2020Print
Can I use my Sony's Android TV without an Internet connection?
    Yes, it's possible to use the basic TV functions without having an Internet connection. However, to get the most out of your Sony's Android TV, we recommend you connect your TV to the Internet.
    You can connect your TV to the Internet during the  Initial Setup , or via  Settings/Network screen at any time after the Initial Setup.
