Article ID : 00113674 / Last Modified : 17/07/2019
Connecting to a network on your Sony's Android TV
How to connect to a network using a wireless connection
The built-in wireless LAN device allows you to access the Internet and enjoy the benefits of networking in a cable-free environment.
(A) PC
(B) Wireless router (access point)
(C) Modem
(D) Internet
Android - Network connected devices (abcd)
  1. Set up your wireless router (or access point).
    For details, refer to the instruction manual of your wireless router (or access point), or contact the person who set up the network (network administrator).
  2. Press the HOME button, then select [Settings]* > [Network] > [Network setup] > [Easy].
    HOME
    Android - Home
    Settings*
    Android - Settings
    Network
    Android - Network setup
    Network setup [Easy]
  3. Choose Wi-Fi and follow the on-screen instructions to complete the set-up.
NOTES:
  • Your connected network should also be displayed on the 'Settings' media shelf next to the 'Settings' icon.
  • When entering Wi-Fi passwords, press OK to bring up the virtual keyboard
To turn off the built-in wireless LAN
Press the HOME button, then select [Settings]* > [Network] > [Advanced settings] > [Built-in Wi-Fi] > [Off].
HOME
Android - Home
Settings*
Android - Settings
Network
Advanced settings
Android - Network advanced settings
Built-in Wi-Fi [Off]
Android - Built-in wifi
NOTES:
  • For smooth video streaming:
    Change the setting of your wireless router (or access point) to 802.11n or 11ac if possible. For details on how to change the setting, refer to the instruction manual of your wireless router (or access point), or contact the person who set up the network (network administrator). If the above procedure does not deliver any improvement, change the setting of your wireless router (or access point) to 5 GHz, which may help improve the video streaming quality.
    The 5 GHz band may not be supported depending on your region/country. If the 5 GHz band is not supported, the TV can only connect to a wireless router (access point) using the 2.4 GHz band.
To use WEP security with a wireless router (or access point), select [Easy] > [Wi-Fi] > [Connect by scan list].
HOME
Android - Home
Settings*
Android - Settings
Network
Wi-Fi
Android - WiFi
Connect by Scan list
Android - Connect by scan list
NOTES:
  • The setting items (e.g. IP address, subnet mask, DHCP) may vary depending on the Internet service provider or router. For details, refer to the instruction manuals provided by the Internet service provider or those supplied with the router. You can also contact the person who set up the network (network administrator).
  • If you select the [Show password] option in the password entry screen, the exposed password may be seen by other individuals.
Connecting to a network using a LAN Cable
A wired LAN connection allows you to access the Internet and your home network. Connect a LAN cable to your TV.
  • LAN cable
  • PC
  • Modem with router functions
  • Internet
Android - Wired (LAN Cable)
  1. Set up your LAN router.
    For details, refer to the instruction manual of your LAN router, or contact the person who set up the network (network administrator).
    HOME
    Android - Home
    Settings*
    Android - Settings
    Network
  3. Choose Wired Lan and follow the on-screen instructions to complete the set-up.
NOTES:
  • The screenshots provided here are for reference only. The actual screen might differ slightly according to your country, model or firmware version.
  •  *For Android Oreo (OSV-O), the settings icon is located in the top right-hand corner
