Article ID : 00118722 / Last Modified : 20/05/2015Print
    Frequently Asked Questions (FAQs) about the Live Mode Video function of the Smart Tennis Sensor.
    • Q1: Where are the play data and videos filmed with Live Mode Video saved on the mobile device?
      A1: The play data and videos filmed with Live Mode Video are saved in the Smart Tennis Sensor folder on your mobile device.
    • Q2: Is it possible to change the destination folder and save the data on an SD card? A2: It is not possible to change the destination folder where the data are saved.
    • Q3: Is it possible to save, manage and edit the data on a computer?
      A3: It is not possible to save, manage, and edit the data on a computer.
    • Q4: Are videos filmed with the Live Mode Video and its play data backed up by the Server Sync function?
      A4: Only the play data can be backed up Server Sync function.
