Article ID : 00118975 / Last Modified : 21/05/2015Print
    How to register the Smart Tennis Sensor to an Android/iOS device?
    Here are the steps to REGISTER the Smart Tennis Sensor to an Android / iOS device.
    For Android devices:
    Step 1: Prepare the Smart Tennis Sensor.
    1. To turn on the Smart Tennis Sensor, press the POWER button for 2 (two) seconds.
    2. The red or blue light will slowly turn on. Hold down the Bluetooth button.
    NOTE: Although the blue light turns on immediately after the button is pressed, just continue to press and hold the Bluetooth button or more than seven seconds until the blue light starts flashing softly.
    Step 2: Prepare the Android device.
    NOTE: The steps to TURN ON the Bluetooth function may vary depending on the device. Please refer to the instruction manual of the device being used for further details.
    1. Turn OFF the Android device.
    2. Turn the power ON.
    3. Tap Settings.
    Turn the Bluetooth switch to ON, then tap on the word Bluetooth.
    Step 3: Pair both devices using Bluetooth.
    1. Tap on Search for Device. Usually this option is located at the top of the screen for Bluetooth settings. This refers to a key feature which can be in a different location depending on the model. Check on the Menu button and select Search for Device.
      NOTE: Confirm that [SSE-TN1...] is displayed in the list of  Available Devices.
    2. Tap this listed item and confirm that the status of [SSE-TN1...] has changed to [Connected]. Pairing will start.
      Once the process has been completed, the blue light on the Smart Tennis Sensor will flash four times.
    3. Return to the HOME screen by tapping on the HOME button and start the Smart Tennis Sensor app. If the message Sensor is Connected is displayed beside an illustration of a racket, then configurations have been completed.
    For iOS Devices:
    Step 1: Prepare the sensor.
    1. Turn the Tennis Sensor on by pressing the Power button for two seconds.
    2. The red or blue light will slowly turn on. Hold down the Bluetooth button. Although a blue light turns on immediately after the button is pressed, continue to hold the button down for more than seven seconds. The blue light will respond by flashing softly.
    NOTE: The key to this operation is to continue to press and hold the Bluetooth button even after the blue light turns on.
    Step 2: Prepare the iOS device.
    1. Turn off the iOS device. Turn the power off by holding down the lock button of the iOS device.
    2. Turn on the iOS device.
    3. Tap Settings.
    4. Check the Bluetooth option and confirm that the switch is on.
    Step 3: Start the pairing.
