Article ID : 00118510 / Last Modified : 17/04/2019Print
    Unable to pair the Smart Tennis Sensor with my mobile device.
    This error message may appear when you are using the Smart Tennis Sensor app on a mobile device which is not supported.
    The Smart Tennis Sensor app is compatible with devices running either of the following operating systems:
    • Android OS version 4.1 or later
    • Apple iOS version 6.1 or later
