General information related to charging the Walkman
You can find below a couple of key points related to the use and charge of your WALKMAN's battery:
- Before the first use of the WALKMAN, it is required to fully charge the battery
- Charging must be done by connecting the WALKMAN to a running computer (via USB)
- The charging time takes up to 4 hours, until the battery indicator displays “FULL”
- When the battery is completely discharged, it may take up to 5 minutes before the device reacts normally after being connected to the running computer - this is the normal operation of the device
- The WALKMAN cannot be operated while charging with a computer
- The WALKMAN should be connected to the computer after the computer is turned on
