Does the supplied remote control support voice recognition?
    Article ID : 00121508 / Last Modified : 12/06/2026Print
    The Microphone button/voice command function does not work on my TV remote control.
    Before you start
    Prior to performing further troubleshooting steps, confirm whether the remote control has a Microphone  button or mark. Remote controls that support voice recognition will have that button or mark.
    Notes:
    • The location of the Microphone  button or mark on the remote control varies depending on your region and model. Refer to the manual for details.
    • If the Microphone  button/voice command function does not work on your Voice command remote control after updating the TV or replacing your remote control, refer to the How to pair or re-pair your wireless or Voice command remote control to your Google TV™ or Android TV™ article.
    • For Google TV™ models: If the TV is set up as a basic TV, voice recognition via remote control does not work. The TV must be set up as a Google TV.
    For TVs that do not come with a remote control with a Microphone  button or mark, you can use one of these two alternatives to the voice recognition function of the TV.
    1. Use a software keyboard.
    2. Use the Google TV application on your mobile device or tablet.
      Note: In this case, it is necessary to connect your smartphone or tablet to the same network as the TV.
      For details about OS versions that support Google TV, refer to the appropriate page:
    Troubleshooting steps
    If voice recognition does not work, even when you use a remote control that supports this function, check the following items.
    1. For models that have Voice control settings, make sure the Voice control function is turned On.
    1. Open the Settings screen.
    2. The next steps will depend on your TV menu options:
      • Select Accounts and Profiles → (Login Name) → Voice AssistantVoice controlOn.
      • Select Accounts and Sign In → (Login Name) → Google AssistantVoice controlOn.
      Note: If the above settings are not shown, skip this step.
    2. Make sure your TV can connect to the Internet.
    Follow the steps below to confirm that your TV can connect to the Internet.
      • Select Network & Internet → Network status → Check Connection.
      • Select Network → Advanced settings → Network status → Check Connection.
      Notes:
      • An Internet connection is necessary to use voice recognition.
      • Depending on the model, you can also check the Internet connection status by pressing the HELP button, then selecting Internet connectivity symptoms or Status & DiagnosticsInternet connection diagnostics.
      • For W8, X7, and X74H_X75H series, check the connected network status under the Network & Internet option.
    If the network diagnosis result is not OK, refer to the How to perform a network diagnosis when the Android TV™ or Google TV™ can't connect to the Internet. article.
    3. Pair your remote control with your Android TV or Google TV.
    Note: If you are using the Touchpad Remote Control for models released in 2015, refer to the How to pair the Touchpad Remote Control with the TV article.
    1. Check if the remote control is registered.
      Note: If your model was released in 2020 or later (except for the BRAVIA 2 (S20), W8x5_W8x6, W8L, X64L_X70L_X74L_X75L, X77L_X78L, W8K, X74K_X75K, W8, X7, and X74H_X75H series), you can skip this step. Refer to the 2. Register the remote control section.
        • Select Remotes & Accessories → Bluetooth Settings.
        • Select Remotes & Accessories.
        • Select Bluetooth settings.
      3. Check if SONY TV RC MIC 001 or SONY TV VRC 001 is registered.
    2. Register the remote control.
        • Select Remotes & Accessories → Remote control → Connect via Bluetooth or Activate  button.
        • Select BRAVIA Settings → Voice Remote Control.
        • Select Remote control → Connect via Bluetooth.
        • Select Voice Remote Control → Activate  button.
      3. Follow the onscreen instructions.
        Notes:
        • Except for RMF-TX940 and RMF-TX920: Pairing can fail if the battery level is low. Replace the batteries and try pairing again.
        • Only for RMF-TX940 and RMF-TX920: Pairing can fail if the battery level is low. Charge the battery and try pairing again.
    4. Speak into the built-in microphone located at the top of the remote control in one of the following ways:
    • For Google TVs: On the remote control, press and hold the Microphone button. While holding the Microphone button, speak into the microphone on the remote control.
    • For Android TVs: On the remote control, press the Microphone button and then speak into the microphone.
    Position the microphone closer to your mouth, or speak in a loud and clear voice.
    Note: The microphone is usually located at the top or just above the center of the remote (the location may differ depending on your remote control).
    5. Check if the circumstance that can use voice recognition.
    Voice recognition cannot be used in all circumstances. Additional information about the different The Search box does not appear, even when I press the Microphone button on the Remote Control is available.
    6. Remove and then re-insert the remote control batteries, or charge them.
    If the issue persists, try following the steps below:
    • Except for RMF-TX940 and RMF-TX920: Remove and re-insert the batteries.
    • Only for RMF-TX940 and RMF-TX920: Charge the batteries.
    7. Update the remote control software.
    Symptoms may improve by updating the remote control software. Check whether there is a software update available for the remote control. For details, refer to the How to perform a TV remote control software update article.
    8. Reset your Android TV or Google TV.
    For more information, refer to the How to restart (reset) a Google TV™ or Android TV™? article.
