Article ID : 00107099 / Last Modified : 29/01/2015Print
    Frequently Asked Questions related to Screen Mirroring for my Home Cinema
    What is Screen mirroring?
    How can I perform Screen mirroring?
    Can I perform Screen mirroring using the NFC function?
    How can I perform Screen mirroring using the NFC function?
    Why can't I access Wi-fi when using Screen mirroring?
    Why can't I establish a Screen mirroring connection?
    “Screen mirroring” is a feature developed by Miracast technology which makes it possible to display the screen of a mobile device on a TV. The main unit can be connected directly to a Screen mirroring compatible device (e.g. smartphone, tablet). You can then enjoy the display of the mobile device on your large TV screen. No wireless router (or access point) is required to use this feature.
    Select Screen Mirroring under the Input menu OR press the MIRRORING key on the remote control. Then, activate the Screen mirroring feature on your mobile device.
    For more details on how to activate the function, refer to the operating instructions supplied with your mobile device.
    Yes. You can perform Screen mirroring using NFC, but make sure that the mobile device is compatible with Screen mirroring/Miracast.
    1) Press the MIRRORING key on the remote control.
    2) Hold the smartphone near the N-Mark logo on the main unit until the smartphone vibrates.
    3) Once the connection is established, the display of the smartphone should appear on the TV screen.
    Why can't I access Wi-Fi when using Screen mirroring?
    Some network functions may not be available during screen mirroring.
    Please try the following:
    1) Make sure the remote device (smart phone) you are trying to connect supports the Screen mirroring feature.
    2) Press the MIRRORING key on remote control.
    3) Open the Screen mirroring application on your mobile device.
    4) Follow the on-screen instructions.
