Some buttons from the remote control don't work when using MirrorLink. Can this be solved?
According to the application and the smartphone model you are using, there may be compatibility issues.
Please refer to the MirrorLink Compatibility Information Web page to make sure your smartphone is compatible with the MirrorLink feature.
