How to register the Touchpad remote control.
- Using the TV remote, press the Home button.
- Go to Settings.
- Select System Settings.
- Select Touchpad Remote Control Setup, then follow the on-screen instructions.
- Using the Touchpad Remote Control, press and hold the Volume down key.
- Then press the SOCIAL VIEW key for longer than 3 seconds while keeping the Volume down key pressed to register the Touchpad remote control.
