Article ID : 00076381 / Last Modified : 13/11/2017Print
    It is difficult to make a selection on the TV when using the touch pad remote.
    Follow these steps if it is difficult to select an item on the TV using the touch pad remote because the pointer moves or jumps around the screen when attempting to make a selection:
    1. Press the Home button.
    2. Select Settings.
    3. Select System Settings.
    4. Select Touchpad configurations.
    5. Select Sensitivity Setting.
    6. Select Low.
