Article ID : 00177214 / Last Modified : 29/05/2017
What do the error codes mean that appear when trying to use the Wi-Fi Direct feature.
     Error Code
     Explanation
    The number of characters is invalid. Please check your entry and try again. Press RETURN (or BACK) to go back.
    The start button is pressed when the WPS PIN code entered was not 4 or 8 digits in length. Some device allows 4, others allow 8 digits.
    The PIN code is incorrect. Please check your entry and try again. Press RETURN (or BACK) to go back. The start button is pressed after entering an invalid PIN code on Enter PIN screen. Enter the correct PIN to resolve.
    Registration failed due to authentication error. Press RETURN (or BACK) to go back. Additional information is available to resolve authentication  errors.
    Registration failed due to request from other device. Press RETURN (or BACK) to go back. Another WPS device is already registered. Disconnect the other device and try again later.
    Registration failed. Press RETURN (or BACK) to go back. Connection set up has timed out. Complete the connection set up within 2 minutes after selecting Start on the television screen.
