Article ID : 00121556 / Last Modified : 29/08/2017
How to set up and use the Wi-Fi Direct feature of the Android TV with Wi-Fi Direct capable device.
Please refer following settings:
IMPORTANT: This is a model-specific solution, view the Applicable Products and Categories for this article to verify that these specifications apply to your model.
  1. Enable the Built-in Wi-Fi setting on your TV.
    1. Using the TV remote control, press the HOME button.
    2. Select Settings.
    3. Select Network in the NETWORK & ACCESSORIES category.
    4. Select Advanced settings.
    5. Select Built-in Wi-Fi, and change to On.
  2. Turn on the Wi-Fi Direct setting of the TV.
    2. Select Settings.
    4. Select Wi-Fi Direct, and change to On.
  3. Display the TV's WPA key.
    2. Select Settings.
    4. Select Wi-Fi Direct.
    5. Select Wi-Fi Direct Settings.
    6. Select  Show Network (SSID)/Password.
    7. The SSID and the WPA key will be displayed on the TV screen.
    8. On the Wi-Fi setting of the Wi-Fi Direct device, select the SSID of the TV and enter the WPA Key displayed on the TV screen as the password.
    9. If the connection is successful, the message Wi-Fi device is connected, is displayed on the TV screen.
      NOTE: For more details refer to the manual supplied with your smartphone or tablet.
