Article ID : 00118301 / Last Modified : 28/11/2019Print
    The name of the currently playing track is not displayed on the car audio unit.
    If your track names are not being displayed on the car audio unit, it might be because of either of the following:
    • The track may not have the appropriate TAG information. The track information can be updated using a computer.
    • Not all audio file formats support TAG information. A track name may not be displayed according to the audio file format (ex. WAV file).
    • Track names are not displayed while the DEMO (demonstration) mode is displayed on the car audio unit. To turn off the DEMO (demonstration) mode, follow these steps:
    IMPORTANT: If model-specific information is needed, refer to the operating instructions supplied with the car stereo.
    1. Press and hold the SELECT button until the setup display appears.
    2. Press the SELECT button repeatedly until DEMO appears.
    3. Rotate the CONTROL DIAL to select DEMO-OFF.
    4. Press and hold the SELECT button, and the display returns to normal play/reception mode.
