When I touch the smartphone to the wireless boombox, audio system or car stereo, the application selection screen appears.
If the NFC application is installed in your smartphone, the selection screen may appear when you touch the smartphone to the Sony wireless boombox, Micro HiFi Component system or car stereo.
To resolve this issue, select the NFC Easy Connect application and set it to use default. The application will start automatically the next time the NFC function is used.
NOTES:
- To change the settings of the NFC Easy Connect application, check the instruction manual supplied with the smartphone.
- The NFC Easy Connect app is not required if you are using Android 4.1 or later operating systems.
