Article ID : 00158483 / Last Modified : 30/08/2017
How long is the battery life?
The battery life changes depending on the model and the settings. For details see below:
  • RDP-V20iP
    Approx. 5 hours of use
  • SRS-X7
    When the NETWORK OFF/ON switch is OFF: Approx. 6 hours
    When the NETWORK OFF/ON switch is ON: Approx. 3 hours
  • SRS-X11, SRS-X33, SRSXB2, SRS-X1, SRS-HG1
    Approx. 12 hours of use
  • SRS-XB3
    Approx. 24 hours of use
    NOTES:
    • For models other than the above, refer to the manual supplied with the product.
    • The actual battery life will vary depending on the temperature, the equalizer settings of the audio input device, etc.
