What is the maximum and minimum USB storage device size that is supported by Blu-ray Disc players & DVD players?
The Blu-ray Disc player can support the following sizes of USB HDDs, USB memories, and file systems.
NOTE:
- In the case of multiple partitions, only the first partition can be used. Any subsequent partitions cannot be accessed.
- We recommend that you use a Sony external USB HDD or USB memory.
- The Blu-ray Disc player is intended to work with third-party products, but operating is not guaranteed for all USB devices.
- UBP-X800/M2: up to 4TB for USB HDD / up to 2T for USB flash memory
DVD
For the DVP-SR170 - DVP-SR370 & DVP-SR760H: your DVD player only supports FAT. For these units, it means that the supported capacity is limited to 32 GB
Legend:
✔:Compatible
X:Not Compatible
For EU models
Year | Model Name | USB HDD・USB Memory | |||||
Maximum Tested Capacity | File System | ||||||
USB HDD | USB Memory | ||||||
Partition Management | |||||||
MBR | GPT | FAT32 | NTFS | exFAT | |||
2019 | UBP-X800M2 | 2TB | 4TB | 2TB | ✔ | ✔ | ✔ |
2018 | UBP-X700 | ||||||
2017 | UBP-X1000ES UBP-X800 | ||||||
2016 | UHP-H1 BDP-S6700 BDP-S3700 BDP-S1700 | ||||||
2015 | BDP-S6500 BDP-S5500 BDP-S4500 BDP-S3500 BDP-S1500 | ||||||
2014 | BDP-S7200 BDP-S6200 BDP-S5200 BDP-S4200 BDP-S1200 | X | X | ||||
2013 | BDP-S5100 BDP-S4100 BDP-S3100 BDP-S1100 | ||||||
2012 | BDP-S495 BDP-S790 BDP-S590 BDP-S490 BDP-S390 | 64GB | |||||
2011 | BDP-S780 BDP-S480 BDP-S380 BDP-S280 BDP-S185 BDP-S580 BDP-S485 BDP-S383 BDP-S186 | ||||||
2010 | BDP-S770 BDP-S570 BDP-S470 BDP-S373 BDP-S370 | X |
