How to activate or deactivate Demo Mode on the Reader™ Digital Book
Activate Demo Mode
- Press the Home button.
- Tap the Settings tab.
- On the Settings tab, tap Device Shutdown.
- In the Device Shutdown screen, tap Yes.
- Once the Reader Digital Book has shut off, slide the POWER switch on and then simultaneously press and hold down the Next Page Turn button and the Size button.
- The Reader Digital Book will restart automatically. Continue to hold the 2 buttons until the home menu appears.
- Within 1 to 2 minutes, the demo slide show will begin and will rotate images every 2 seconds.
NOTES:
- The user can interrupt the slide show to experience the touch screen display but cannot save any drawings or inappropriate language.
- While in Demo Mode, the Reader Digital Book cannot shut down from the Settings menu.
Deactivate Demo Mode
- Turn the Reader Digital Book off.
- On the bottom of the Reader Digital Book, using a thin object such as a paper clip, press the RESET button.
NOTE: The device is now out of Demo Mode and will shut down from the Settings menu.
