Article ID : 00337032 / Last Modified : 28/10/2024Print
    Updating your Sony Headphones
    Transcript
    If you're looking to update your Sony headphones, the way to do it is by using the Sony Headphones Connect app. You can download this app from the App Store on your phone. Once installed, connect your headphones to your phone via Bluetooth as you normally would. If you need guidance on how to do that, there is a link in the description to another video that will walk you through the process.
    Once the app is installed and your headphones are connected to your phone, if there is an update available, the app will automatically detect it. The Headphones Connect app will then download and transfer the data to your headphones without any manual intervention.
    The next time you open the app, you'll see that there's an update ready to go. Simply press "more info" and proceed to finalize the update. During the update process, it's essential not to turn off your headphones or connect them to a charger, as this may interrupt the update.
    It's worth noting that updates and data transfers can take some time to complete. If you inadvertently interrupt the update, don't worry – it will start again from the beginning the next time you connect your headphones to your phone.
    And that's it. Enjoy your music, and thank you for watching.
    This video supports subtitles.
    How to turn captions on or off when watching Internet videos from YouTube.
