Article ID : 00381966 / Last Modified : 11/06/2026Print
    The Noise Canceling effect is weak or not working (WF-1000XM6)
    Follow these steps to troubleshoot this issue:
    Before you start
    • Check if the headphones are worn properly:
      • If there is too much space between your ear and the headphone earbud, the Noise Canceling function may not work as well as it should. Examine the earbuds starting with the bigger size tips to find the one that fits best. The best size earbud tip may be different for the left and right ears.
      • When you put them into your ears, pinch the earbuds with your thumb, index finger, and middle finger, then rotate and push them firmly into your ears. If it is difficult to push the earbuds firmly into your ears, slightly crush the earbud tips to make it easier.
    • If any dirt is left on the air holes of the earbuds, the Noise Canceling function may not work well. To prevent this, clean the vent holes on the earbuds.
    • If the issue only occurs during a phone call, refer to the article Noise canceling doesn't work, or white noise is heard during a call on the headphones.
    Solution
    1. Turn on the Noise Canceling function.
      While wearing the headphones, tap the L (left) touch sensor to turn on the Noise Canceling function. You will hear a notification sound from both sides at the same time (or from the left side when only the left unit is worn).
      Note: In the default setting, you can switch between the Noise Canceling and Ambient Sound functions by tapping the L (left) touch sensor.
      You can view the video on how to use the Noise Canceling feature:
      The Noise Canceling function works
      The issue was caused because the Noise Canceling function was Off.
      The Noise Canceling function does not work
      Go to the next troubleshooting step.
    2. Change the headphones' settings using the Sony | Sound Connect app.
      When the Adaptive Sound Control is set to On, the headphones detect your action (running, walking, etc.) and automatically switches the settings of the Noise Canceling function to Ambient Sound Control. To make maximum use of the Noise Canceling function, follow these steps to set the Adaptive Sound Control to off, and adjust the Noise Canceling or Ambient Sound Control manually.
      Note: If the Adaptive Sound Control is set to On, the Noise Canceling is adjusted and Adaptive Sound Control is activated according to your action.
      1. Turn off the Adaptive Sound Control.
        1. Connect the headphones and smartphone via Bluetooth, and then launch the Sony | Sound Connect app.
        2. In the My Device tab, check the Adaptive Sound Control status. If the status shows other than Off (Staying, Walking, etc.), select right arrow on the right side of the Adaptive Sound Control menu.
        3. Turn off the Adaptive Sound Control.
      2. Select Noise Canceling to turn the setting On.
      The issue was caused by the headphones' settings.
    3. Fit the headphones to your ears firmly.
      If the earbuds do not fit your ears, the Noise Canceling function may be significantly affected. To maintain the quality, consider these factors:
      • Make sure that headphones are worn properly
      • Make sure that the earbud tips are firmly and completely attached. If you are using the optional earbuds (EP-NI1010), lightly turn over the earbud tips to make sure that the sound output hole is completely covered by the earbud tip.
      • Select the earbud tips that best fit your ears. Measure the air-tightness of the earbud tips and find the optimal size using the Sony | Sound Connect app. In the My Device tab, select All device settings → Wearing → Check wearing condition and earbud tips → Determines Optimal Earbud Tips, and follow the on-screen instructions to adjust the setting.
      For additional details, refer to the article How to wear the earbud headphones and select the right size earbud tips.
      The size or fitting conditions may have affected the Noise Canceling function.
    4. Reset (restart) the headphones.
      Refer to the How to reset or initialize the WF-1000XM6 article or view the How to reset video below:
      If your headphones model does not appear in the device list of the playback device after the reset, turn off the Bluetooth setting in the device and turn it on again, or leave the Bluetooth setting once and return to try the connection again.
      The issue may be caused by a temporary malfunction of the headphones.
    5. Initialize the headphones.
      Initialization returns the headphones to the factory settings and all Bluetooth pairing information is deleted.
      The Noise Canceling function is most effective for low frequency (bass) noise, such as noise made by vehicles or air conditioning, but not all sounds can be completely canceled. Try other conditions to test the effectiveness of the Noise Canceling function.
