Article ID : 00247113 / Last Modified : 26/06/2022Print
Gaming Console - Composite
    Making a Connection
    The connection method depends on the terminals of the TV.
    If the TV has a VIDEO IN terminal (yellow)
    Connect the video (yellow) pin of the composite A/V cable to VIDEO IN (VIDEO/yellow) on the TV, and the audio (red and white) pins to VIDEO IN (AUDIO R/L) on the TV. Connect the other end of the composite A/V cable to the Gaming console.
    Image of connecting TV and Gaming Console with composite cable
    1. Gaming console
    2. Composite A/V cable
    3. TV: VIDEO IN
    If the TV has a VIDEO IN terminal (green)
    Connect the video (yellow) pin of the composite A/V cable to VIDEO IN (VIDEO/green) on the TV, and the audio (red and white) pins to VIDEO IN (AUDIO R/L) on the TV. Connect the other end of the composite A/V cable to the Gaming console.
    1. Gaming console
    3. TV: VIDEO IN
    If the TV has a VIDEO IN or AV IN terminal (4 pole mini plug)
    Connect the video (yellow) pin and the audio (red and white) pins of the composite A/V cable to the sockets on the RCA side of the 4 pole mini plug RCA conversion cable (Analog Extension cable), and connect the other end to the Gaming console.
    Connect the pin on the mini plug side of the 4 pole mini plug RCA conversion cable (Analog Extension cable) to VIDEO IN or AV IN (4 pole mini plug) on the TV.
    Image of connecting TV and Gaming Console with Composite Audio/Video cable and 4 pole mini-plug RCA conversion cable
    1. Gaming console
    3. 4 pole mini plug RCA conversion cable (Analog Extension cable)
    4. TV: VIDEO IN or AV IN (4 pole mini plug)
    TV Set-up
    1. After making a connection, turn on your TV.
    2. Press the (Input) button repeatedly to select the input to the connected Gaming console.
      Image of remote control
    3. Turn on your Gaming console by pressing the power button.
