Article ID : 00200442 / Last Modified : 10/02/2026Print
How to reduce input lag on your TV or monitor when using the Game setting
    IMPORTANT: This article applies only to specific products and/or operating systems. Check the Applicable Products and Categories section of this article before starting these steps.
    Before you start
    • When you're playing HDR video games and using an HDMI input on your TV, make sure you select the appropriate HDMI input on your TV. Then, follow the correct steps below.
    • Before performing the steps, make sure that your Android TV™ or Google TV™ has the latest software version installed.
    The method for reducing input lag when using the Game setting varies depending on your model.
