Article ID : 00122377 / Last Modified : 11/03/2016Print
    Unexpected behaviour of the set when pressing the “TV” button on the remote control
    You may have unexpectedly assigned the "TV" button on your remote to an external input, causing your TV to behave not as you would have originally intended. For example, customising the "TV" button to select the HDMI input every time you use the TV button in the future.
    If you've mapped the "TV" button to an input that you wish to change, adapt the user settings by using the following path:
    [HOME] > [Settings] > [External inputs] > [Customise TV key] > select the option you wish to use.
