IMPORTANT:
This article covers the latest Sony TV remote, its buttons, and their functions. However, the most important buttons and their functions are standard for most TV remotes!
Don’t worry; a selection of remotes is at the bottom of this article. Click on the image that best matches your remote to view all button functions in the Help Guide.
Understanding your remote control buttons
Check out this video tutorial to learn about the functions of the new TV remote, or you can refer to the descriptions below.
Understanding your remote control - Power, TV, and Settings
Understanding your remote control - Input, navigation, MENU, 123, and Home
Understanding your remote control - Volume, Channel, and Google Assistant
Understanding your remote control - Play, Pause, Guide, and Streaming apps
Remote control overview
- Click on the remote control image to visit the remote help guide. Each guide explains all the upper, middle, and lower buttons.
- If your remote control is not the one displayed below, you can refer to this FAQ:
How can I find support information about the remote control bundled with my TV?
