Article ID : 00347203 / Last Modified : 20/01/2026Print
    How do I open the back cover of my remote control and change the batteries?
    This article explains how to remove the battery cover to replace the battery or to check the name of the remote control written inside the battery compartment.
    Table of contents
    How to open the back cover of the remote
    When your remote is not performing as expected, the most common solution is to replace the batteries. However, TV remotes come in many shapes and sizes, and depending on the remote you're using, the mechanism to open the back cover is different. Let's have a look at some common mechanisms.
    Note: If the cover is a bit stuck and difficult to open, wearing rubber gloves or anti-slip gloves will make it easier to open.
    The slide and peel
    1. Turn the remote control over, point the triangle symbol on the top of the cover (marked with the red circle in the picture) upward, and place your thumbs at the underside of the cover.
      Picture of holding the remote with both thumbs underneath. The tip of the remote has a triangle mark with a red circle indicating its position.
    2. Slide the back cover in the direction of the  triangle point until it loosens.
      Note: When opening the cover for the first time, it may not slide easily.
    3. Lift the back cover to open it.
    The slider (a part of the cover)
    Slider remotes require you to slide either a part of the back cover or the entire back cover in one direction, possibly marked by a triangle.
    The clip and tilt
    Very common and easily identifiable: You recognise the battery compartment on the back of the remote by the clearly defined lid. Usually, there is a little clip you can press to remove the cover.
    The arrow
    Arrow remotes have a button on the underside of the remote. If you press the arrow, the entire back cover will come loose, revealing the battery compartment.
    How to replace the batteries
    Insert the battery according to the indicated polarity, starting with the negative (-) pole. Follow the markings in the battery compartment.
    Battery tips
    • The battery of rechargeable remote controls cannot be replaced.
    • Do not mix new and used batteries or different types of batteries.
    • While alkaline batteries are acceptable, we recommend manganese batteries.
    • For remotes with a mic button or touchpad, we recommend using alkaline batteries with long battery life for reliable Bluetooth communication.
    • Remove the batteries if they are depleted or if the remote hasn't been used for a long time. Leaving the batteries in can cause the battery to leak.
    • If battery fluid leaks, clean the battery compartment thoroughly before inserting new batteries. If the fluid contacts your skin, rinse thoroughly with water.
