Tactile dots on the TV remote buttons
The TV remote control has tactile dots on these buttons to help you locate the target button easily:
- PLAY
- PLAY/PAUSE
- AUDIO
- numerical 5
- Channel Up
For example, the Channel and Volume buttons are the same shape, but you can distinguish between them because the Channel Up button has a tactile dot.
- The Volume and Channel buttons have the same shape, but only the + (Plus) mark on the Channel button has a tactile dot, allowing you to distinguish between them.
- Only the numerical 5 button has a tactile dot, which helps you locate the rest of the numerical buttons.
