Article ID : 00133616 / Last Modified : 24/09/2018Print
    How can I restrict or allow apps using the Restricted Profile function?
    What's the Restricted Profile?
    The Restricted Profile function prevents access to certain apps or services when enabled.
    How do I set up a Restricted Profile?
    Please use the following instructions:
    • [HOME]
    • [Settings]*
    • [Personal - Security & restrictions] > [Restricted profile] > [Settings]
    • Set up a new 4-digit PIN  & Re-enter your PIN to confirm
    • Choose [Allowed apps]
    • Select your chosen app > [Allowed / Not allowed]
    Accessing your Restricted Profile
    To start using your Restricted Profile on Sony's Android TV, please use the following steps:
    • [HOME] > [Restricted profile] icon in the settings menu
    • [Enter Restricted profile].
    • A new message "Switching to Restricted Profile" will appear on-screen before the function is activated.
    To exit your Restricted Profile, enter the category, select [Exit Restricted profile] and enter your 4-digit PIN.
    A message "Switching owner" will appear on-screen to confirm the function has been deactivated.
    Changing the PIN in your Restricted Profile
    You can also change your PIN using the following settings:
    • [HOME] > [Settings]*
    • [Personal - Security & restriction] > [Restricted profile] > [Settings]
    • [Change PIN]
    • Enter your old 4-digit PIN
    • Choose a new PIN > Re-enter your new PIN to confirm.
    Deleting your Restricted Profile
    Finally, you can delete your Restricted Profile by selecting:
    • [HOME] > [Settings] > [Personal - Security & restriction]*
    • [Restricted profile] > [Delete restricted profile]
    • Enter your 4-digit PIN
    *NOTE: For Android Oreo (OSV-O), the settings icon is located in the top right-hand corner.
    How to set or cancel a PIN code for Sony's Android TV
