Article ID : 00412688 / Last Modified : 28/09/2026Print
    I cannot download, install, or update any applications from the Google Play Store.
    When I try to download, install, or update an app from the Google Play Store:
    • Applications cannot be installed from the Google Play, Install pending... is shown on their icon in HOME menu.
    • A Server error message appears and I cannot access the Google Play Store.
    Troubleshooting steps
    1. Check the available storage space. To download an application, the available storage space must be larger than the application size to be installed.
      Note: If you download an application when the storage is full, the Server error message appears, and you will be unable to access the Google Play Store.
      1. Open the Settings screen.
      2. The next steps will depend on your TV menu options:
        • Select System → Storage → Internal shared storage → Available.
        • Select System → Storage —Internal shared storage(except for system area) → Available.
        • Select Device Preferences → Storage → Internal shared storage → Available.
        • Select Storage & reset → Internal shared storage → Available.
        • Select Storage & reset → Storage → Available.
    2. If your TV has a Delete demo content setting, perform the following:
      Note: No demo content found message might be displayed that cannot be deleted.
        • Select System → Storage → Delete demo content → OK.
        • Select Device Preferences → Storage → Delete demo content → OK.
    3. If your TV has one of the following settings, perform a cached data clear:
      Note: Immediately after deleting the cache data, some thumbnails on the HOME screen might be displayed as gray squares.
        • Select System → Storage → Internal shared storage (except for system area) → Cached data → Clear cached data? → OK.
        • Select Device Preferences → Storage → Internal shared storage → Cached data → Clear cached data? → OK.
    4. When there is not sufficient available storage space, follow these steps to uninstall unnecessary applications:
      Note: When an application is uninstalled, all data related to the application is also erased.
        • Select Apps → See all apps.
        • Select Apps → See all apps, and then check the Installed apps category.
        • Select Apps, and then check the Downloaded apps category.
      3. Select an application to uninstall.
      4. Select Uninstall.
      5. Select OK.
    5. Reset the TV. For how to reset the TV, refer to the How to restart (reset) an Android TV™ or Google TV™? article.
    6. For Android™ 9 or earlier, if the measures above do not solve the problem, follow the instructions below:
      Note: You cannot install restricted applications when the Parental controls have been set. Check the settings by performing the following procedure:
      1. Press the HOME button on the remote control.
        • Select Apps → Google Play Store → Settings → Parental controls.
        • Select Google Play Store → Settings → Parental controls or Parental controls Settings.
