Article ID : 00343996 / Last Modified : 06/08/2026Print
    Noise is heard from the projector (VPL-XW Series)
    IMPORTANT: This article applies only to specific products. Check the Applicable Products and Categories section of this article for details.
    If the issue occurs, check the following:
    Content
    1. VPL-XW7000 only: The noise occurs when adjusting the FOCUS, ZOOM, or SHIFT
    2. Check the installation environment
    3. Change the settings
    Troubleshooting
    1.VPL-XW7000 only: The noise occurs when adjusting the FOCUS, ZOOM, or SHIFT
    A small amount of electrical noise is normal when using the lens for FOCUS, ZOOM, or SHIFT. If these functions work smoothly, the projector is functioning correctly.
    Some environmental factors can cause noise. To avoid this, make sure there are no problems with how or where the projector is installed:
    1. Near walls: To maintain the performance and reliability of the projector, leave a space between the walls and the projector as illustrated:
      • Viewing the projector from the top
        Illustration indicating the distance (rear (B), left (A), right (A)) between the projector and surrounding walls when viewed from above
        • A: 30 cm (11 7/8 inches)
        • B: 5 cm (2 inches)
      • Viewing the projector from the front
        Illustration indicating the distance (upper (B), left (A), right (A)) between the projector and surrounding walls when viewed from the front
        • B: 15 cm (6 inches
    2. Avoid poor ventilation: Leave at least 30 cm (11 7/8 inches) of open space around the projector.
    3. Avoid heat and humidity: Do not install the projector near stoves or heaters.
    4. Avoid locations subject to direct cool or warm air from an air conditioner or furnace: Installing the projector near an air conditioner or furnace may cause a malfunction due to moisture condensation or a rise in temperature.
    Note: For details on the procedure to change the settings, please take a look at the Help Guide.
    1. Change the Output of the Laser Light Setting to minimise, and check if the noise decreases.
    2. Change the High Altitude Mode setting. The noise will be less when the High Altitude Mode setting is Off, Level 1, or Level 1 rather than Level 2.
      WARNING! When using the projector in a location at an altitude of 1,000m or higher, setting the High Altitude Mode to Off may cause a malfunction. If this is the case, keep the setting and proceed to the next step.
    3. Keeping the room temperature 25°or lower will limit the need for the fan, which can help reduce noise. To display the projector's intake air temperature, check the Intake Air Temperature.
    4. After checking the settings above, set the Output of the Laser Light Setting to the desired brightness.
      • Dynamic Control: Full, Limited, or Off
      • Output: Desired value
        Note: Any noise produced is quietest when Output is set to the minimum.
    If the issue is not resolved, service may be required.
