Article ID : 00344004 / Last Modified : 06/08/2026Print
    Images from the projector are out of focus (VPL-XW Series)
    IMPORTANT: This article applies only to specific products. Check the Applicable Products and Categories section of this article for details.
    Check the Before you start section, then select the appropriate issue depending on the situation.
    Content
    Before you start
    Regardless of the situation, first check the following:
    Issue 1: When the image is out of focus from the beginning
    If the front of the projector is not parallel to the screen, the image might be out of focus.
    It also may cause the center and four corners of the screen to be out of focus at the same time. For details, check the following:
    Issue 2: When the image was in focus at first but has become out of focus after using the projector
    Check the installation environment, and make sure the issue is resolved using your preferred images.
    If the issue is not resolved, service may be required.
