Article ID : 00185224 / Last Modified : 13/01/2022
No sound is output from the subwoofer
    Follow the instructions according to the symptom and check the sound after each step. If model-specific information is needed to perform any step, check the product manual. Manuals are posted on our support page
    NOTE: If you have the HT-RT5 Soundbar and no sound is output from the surround speaker, the following instructions are the same as for the subwoofer.
    Follow these steps to troubleshoot the issue:
    1. Verify that the subwoofer is turned ON.
      • If any LED indicator is lit or flashing, the power is ON.
    2. On the remote control, press the SW + (subwoofer volume) or Bass button to turn up the volume of the subwoofer.
      • The button name may vary depending on the model.
    3. Check the status of the subwoofer LED indicator.
      • When the LED lights up in red after turning on the audio device, the link or the connection between the Soundbar speaker and the subwoofer may not be complete. Set the link settings again. For details, refer to the instructions manual
      • Examples of headings sections in the instructions manual
      • When the LED flashes (slowly) in green or orange and lights up in red after 10 seconds, move the subwoofer closer to the main unit. Place the subwoofer where there are no obstacles (e.g. furniture, walls, or metal objects), directly between the unit and subwoofer.
        NOTE: The LED may flash slowly in green or orange for more than 10 seconds.
    4. Unplug the AC power cord of the subwoofer, and then plug it in again after one minute. Right after turning on the subwoofer, set the link settings between the Soundbar speaker and the subwoofer again. For how to set the link refer to the product manual
    5. If the issue still occurs, reset or reinitialise the Soundbar. After the reset/reinitialisation, perform the Easy setup process and then set the link settings between the Soundbar speaker and the subwoofer again.
      If your model is not referenced below, check the product manual.
      • Reset or initialise the audio system.
