Help! My Sony TV remote control doesn't work
You're here because your TV remote isn't working properly, or it's not working at all. In this article, we're sharing our top tips for the most common remote control issues and how you can bring your remote control back to life.
Not sure what each button on your remote does? Refer to this article for a detailed overview: What are the button functions of my Sony TV remote control?
Tip: If you're more of a visual learner, definitely check out our video guide below:
Troubleshooting guide
Battery change - Obvious but effective!
Check if your remote control still works
Determine if the issue is caused by your TV or another device
Bonus: Turn your smartphone into a virtual remote
If you still can't operate your TV using the TV remote, TV buttons, or virtual remote, your TV may require service. Please contact us for further assistance.
