Follow the below procedure to uninstall the app from your device.
Android
Select "Settings" > "Apps" or "App Manager"* in your device, tap the B-Trainer icon, then select "Uninstall".
You can also remove the app using the Google Play Store app, by following these steps: from the menu, select "My apps", tap the B-Trainer icon, then tap "Uninstall" on the app page.
* Depending on your device, the screen names and buttons may differ.
For uninstalling instructions, see the documentation or support site of your device.
iOS
At the home screen, press and hold the B-Trainer icon and tap the [x] button that appears on the icon.
* Depending on your iOS version, the screen names and buttons may differ.
