Article ID : 00123030 / Last Modified : 12/07/2018Print
    Frequently asked questions about setting up the Smart B-Trainer and the associated app
    This article discusses some frequently asked questions related to the setup of your Smart B-Trainer and the associated "B-Trainer for Running" app.
    Is there a legally-imposed minimum age in order to use the Smart B-Trainer?
    How to wear the Smart B-Trainer?
    Where can I get the app, and which smartphones are supported?
    Where can I find the current firmware version of the Smart B-Trainer, or the software version of the app?
    How do I uninstall the app?
    Device and App
