INZONE Gaming Monitor: Frequently Asked Questions (FAQ)
INZONE™ gaming monitors help you see more clearly and react faster for invincible gaming. Check out the information below to learn more about the monitor and how to use it.
Select your INZONE Gaming Monitor model
SDM-27Q10L, SDM-27Q10S, SDM-27U9M2
General
What is the INZONE Hub application?
INZONE Hub is computer software that controls INZONE monitors and headsets. It allows you to personalise experiences by customizing a wide range of operations, including a variety of sound and picture settings. You can also assign specific picture modes and sound profiles of the headset to individual computer applications and games.
Operating systems: Windows 11, Windows 10
For more information about the INZONE Hub application, refer to the INZONE Hub page.
Notes when connecting to a computer
Check the following:
- Install the latest driver for your graphics board.
- Use a suitable port and cable.
- DisplayPort: Use a supplied DisplayPort cable. We recommend using a DisplayPort for PC connection.
- HDMI: Use an HDMI 2.1 (Ultra High Speed) cable when connecting to an HDMI terminal.
- The computer may be slow when two or more displays are connected. This will depend on your computer and graphics board performance.
- We recommend performing a direct connection without a signal converter or docking station when you have an issue using them.
Specifications
What is TÜV Low Blue Light & Flicker Free Certification?
Please see the TUV_LowBlueLight_FlickerFree.pdf file.
Is each monitor calibrated in the factory before shipping?
Each individual monitor is calibrated on the production line before shipping, and a colour calibration factory report is attached.
Settings
How to adjust the refresh rate and resolution of the monitor
Adjust the refresh rate and resolution on the connected computer or the gaming console.
Troubleshooting
When displaying both setting screens of the INZONE Hub application and the monitor, they do not synchronise.
The settings screens do not change synchronously, but the settings are correctly changed from the INZONE Hub application or the monitor. To synchronise, exit the INZONE Hub application and launch it again, or close the settings screen of the monitor and display it again.
The monitor is not recognised by the INZONE Hub app, and the monitor icon is not displayed in the app
Please exit the PC Widget app and launch it again.
The screen flashes brighter or darker when changing the monitor settings on the INZONE Hub application.
When you select the Sony monitor with multiple monitors connected, the monitor may flash to notify you that the monitor has been selected.
Note: The screen will only flash when the signal is SDR and will not flash during HDR signal.
Some ghosting or inverse ghosting appears when the Response time is set to Faster (for the SDM-27U9M2)
Ghosting or inverse ghosting may appear during fast gameplay when the Response time is set to Faster. This is due to excessive panel overdrive which may cause slight yet noticeable visual artifacts in the image. To avoid ghosting or inverse ghosting, change the Response time to Standard or Fast.
The monitor has some light leakage when playing games in a dark room (for the SDM-27U9M2)
To reduce the blooming or halo effect, try the following setting:
- Set the Local dimming to Low or Off.
Note: The setting may cause the whole screen to look washed out.
The monitor is unable to recognise connected devices after resetting it
Try the following steps:
- Disconnect the AC cable of the monitor and leave it unplugged for 1 minute.
- Connect the AC cable again.
- Turn on the monitor.
A flicker can be seen with specific content (for the SDM-27Q10S)
Try the following:
- Change the VRR setting to Off.
Press the joystick on the back of the monitor to display the setting screen, and then select Gaming assist → Adaptive-Sync/VRR → set to off.
Note: Turning off the VRR setting on the computer may also reduce the issue. - Set the computer's operating system refresh rate to 240Hz.
Note: Tearing may be visible when displaying at 480Hz, depending on the performance of the graphics card.
Does this model have a burn-in warranty? How long is it covered (for the SDM-27Q10L and SDM-27Q10S models)?
Yes, there is a three-year warranty for burn-in.
Notes:
- Normal usage, including gaming, is covered under warranty. However, misuse, abuse, and commercial use are not covered.
- The user manual provides information on which displays to avoid and methods to reduce the risk of image retention to help prevent burn-in. Following these instructions can prolong the lifespan of your monitor.
Static horizontal line noise can be seen on a panel (for the SDM-27Q10L and SDM-27Q10S models)
Try performing a manual Pixel refresh: Select Menu → Panel Settings → Pixel refresh.
Note: Please do not touch the screen during the Pixel refresh. (The Amber LED on the right bottom will blink during Pixel refresh.)
The image below is an example of the screen.
SDM-U27M90, SDM-F27M30
General
What is the monitor design concept?
Considering competitive games as sports, INZONE products were designed as professional gear for game players, which fit the flexible playing style of eSports players.
In combination with PlayStation®5, there is a sense of unity in design. You can combine the monitor with other gaming platforms, including gaming computers.
INZONE Hub is computer software that controls INZONE monitors and headsets. It allows you to personalise experiences by customizing a wide range of operations, including various sound and picture settings. You can also assign the headset's specific picture modes and sound profiles to individual computer applications and games.
What is the KVM switch (Auto switch function)?
You can control two computers or one computer and one gaming console, with a single set of a keyboard, mouse, and headset.
The device controlled by USB devices changes automatically, according to the video input source selected. KVM stands for Keyboard, Video, and Mouse.
How can I clean the monitor?
- Gently wipe the screen or the exterior with a dry, soft cloth, such as an eyeglass cleaner.
- For inks from oil markers on the screen, soak a cloth in a non-soap synthetic cleanser, diluted with water to be less than 1% cleanser. Squeeze the cloth tightly to eliminate excess liquid, then wipe gently to remove the ink. Immediately afterwards, gently wipe the screen with a soft, dry cloth.
- Don't use detergent with abrasives such as a cleanser.
The DisplayPort, HDMI, and USB cables are not supplied in the package.
Cables to connect the devices and the monitor are not supplied as the required cable type, version, or length depends on the customer's environment. The customer should purchase appropriate cables separately.
The supplied AC adaptor is large.
To minimise the desktop space, an AC adapter is selected. Its shape is optimised to reduce the amount of heat generated by the power supply and prevent the adapter from overheating.
When connecting to a computer, check the following:
- Install the latest driver for your computer's graphics board
- Use cables suitable for the type of video signal
- When connecting to a DisplayPort: Use a DisplayPort 1.4 cable
- When connecting to an HDMI terminal: Use an HDMI 2.1 (Ultra High Speed) cable
- When connecting to a USB-C terminal: Use a DisplayPort Alt Mode cable
Specifications
What is the USB port specification?
The specifications are as follows:
Speed
- USB-B: USB 3.0 (5 Gbps)
- USB-C: USB 2.0 (480 Mbps)
- USB-Upstream depends
Charge
- USB-A: 5 V, 0.9 A
- USB-C: 5 V, 3 A
What is the input lag/latency?
For the SDM-U27M90: The input lag time is 4.6 ms, which was measured via 4K/120fps game input based on the internal conditions. The actual lag time may differ in models, real-time usage environments, or specific conditions.
How much is the variable refresh rate range?
- DisplayPort: 48 Hz - 144 Hz
- HDMI: 48 Hz - 120 Hz
What is GtG (Grey-to-Grey)?
GtG (Grey-to-Grey) is a standard method of measuring response time, which is how long it takes to shift from one colour to another. The response time of this model is 1 ms.
Does the monitor have the Backlight Strobing (Black Frame Insertion) feature?
No, it does not support the Backlight Strobing feature.
Each individual monitor is calibrated on the production line before shipping, and a colour calibration factory report is attached. Color accuracy is ΔE(Delta E) < 1 when HDR signal input.
Settings
How to set up the USB Charge.
Set the KVM switch correctly for USB charging. For details, refer to the Help Guide.
Note: Input signal changes are necessary to apply the setting.
What are the restrictions when using Power saving or Eco mode?
For details on the restrictions on Power saving or Eco mode, refer to the Help Guide. In addition to the ones mentioned in the Help Guide, there are the following restrictions:
- Fixed refresh rate to 60 Hz
- Fixed Brightness
What is the difference between Black equalizer in Gaming assist and FPS game in Picture mode?
- FPS game: The setting is the optimum preset mode for shooter games which adjusts colors, contrast, and tone overall.
- Black equalizer: The setting adjusts the tone mapping only so that you can find objects easily in dark scenes.
What can I do with the import/export option in the Device Settings of the INZONE HUB application?
You can save (export) and read (import) items to your computer only in Display Settings.
Note: Items in Device Settings and App Sync Settings cannot be exported or imported.
Troubleshooting
Unable to set Picture Adjustment.
Available settings differ depending on the Preset mode or input signals.
- When the Preset mode is set as Standard, FPS game, or Cinema: Sony provides the best setting by default, and menu items are greyed out.
- When the Preset mode is set to Game1 or Game2: Can be adjusted with the desired settings. If Eco mode is on, the menu items are greyed out.
- When the input signal is HDR: Only the Aspect ratio can be set.
Please exit and relaunch the PC Widget app
The main menu cannot be displayed without an input signal
This is a specification of the product. Only an input selection menu will be displayed when pressing the joystick on the monitor without an input signal.
An Auto picture mode signal was detected... message is displayed on the monitor and cannot be turned off.
When this message appears, use the joystick on the back right side of the monitor, then select either OK or Cancel. It cannot be turned off using a mouse.
Note: The entire message is: Auto picture mode signal was detected. Preset mode and Eco mode settings will be changed. Changing these settings will increase power consumption. (If Cancel, Auto picture mode will be turned off) Select using joystick
The picture mutes and displays a Scanning for signal message when you change the video signal (SDM-U27M90)
This happens when the VRR (Variable Reflash Rate) signal changes from the source device (from Off to On or On to Off). Depending on the VRR signal, it may take some time to adjust the signal frequency when switching. Please wait a moment until the picture refreshes.
Note: Disabling the VRR function on your source device minimises the mute period but you can't enjoy the VRR function.
The USB hub function doesn't work, unable to use a mouse or keyboard that is physically connected to the monitor, or cannot control a device connected to the monitor.
Set the KVM switch correctly, then select the input assigned to KVM switch 1 or KVM switch 2.
Note: For details, refer to the USB hub and Using the KVM switch (Auto switch function) sections in the Help Guide.
I can see shaking on the monitor (for the SDM-U27M90)
This may be improved by setting Adaptive-Sync/VRR to ON.
Notes:
- Set VRR to On when using an HDMI input. (only VRR is displayed on the Settings screen.)
- Set Adaptive-Sync to On when using the DisplayPort or USB-C inputs. (only Adaptive-Sync is displayed on the Settings screen.)
Some ghosting or inverse ghosting appears when the Response time is set to Faster.
The monitor has a stuck pixel.
The LCD panel fitted to this unit is manufactured with high-precision technology, giving a functioning pixel ratio of at least 99.99%. A very small proportion of pixels may be stuck, either always off (black), always on (red, green, or blue), or flashing. This is not a malfunction.
The monitor has some light leakage when playing games in a dark room.
- For the SDM-U27M90: Set the Local dimming to Low or Off.
- For the SDM-F27M30: Set the Dynamic contrast to Low or Off.
The monitor does not stay in standby mode.
Some source equipment produces signals that can cause the monitor to wake from standby mode. To avoid this issue, use the Power button at the bottom of the back of the monitor to turn it off.
Note: By turning the monitor off in this manner, when you turn the monitor back on again you will need to manually turn on the source equipment as well.
Software update
How to update the software of the monitor
When there is an update available, follow these steps to download and install the update using a Windows computer:
Notes:
- A notification will be displayed in the System Software Information section of the INZONE Hub software when a new update is available.
- If you don't have a Windows computer, please refer to the Contact support section of this article.
- Download and install the INZONE hub application.
- Connect the following cables from your computer to the monitor:
- An HDMI (or other) cable to convey the video
- A USB cable to convey data for the update
Settings for the example connection method: In the INZONE Hub software or on the monitor menu, under USB Hub, set the KVM SWITCH 1 to HDMI 1 Sync.
Note: For settings other than the above connection method, refer to the question Connection and settings when updating the software in this article.
Follow these steps to update the monitor software:
- Restart the monitor and computer.
- Start the INZONE Hub software.
- Select Device Settings.
- Select the Update button.
Note: A notification will be displayed in the System Software Information section when a new update is available.
- Read the information on the screen and then select the Update Now button.
Note: Make sure no other monitors are connected to the computer.
Via the monitor screen
- Press the Joystick on the rear of the monitor to display the menu.
- Move the Joystick to the right to select Others-DDC/CI.
- Move the Joystick down and select Software version.
- The software version is shown on the monitor screen.
- Main: Mxxx
- Sub: xxx
Via the INZONE Hub software
- Select the Device Settings tab of INZONE Hub.
- The software version is shown under System Software Information.
- VERSION (MAIN): xxxx
- VERSION (SUB): xxx
Connection and settings when updating the software.
For all connection methods and the corresponding USB Hub setting of the monitor menu or the INZONE Hub software refer to the following:
HDMI port and USB Type-C terminalWhen using HDMI port 1 or HDMI port 2 (A) for the video input connection and the USB Type-C terminal (B) for the USB connection, set the KVM SWITCH 1 to HDMI 1 Sync or HDMI 2 Sync.
When using HDMI port 1 or HDMI port 2 (A) for the video input connection and the USB Type-B terminal (B) for the USB connection, set the KVM SWITCH 2 to HDMI 1 Sync or HDMI 2 Sync.
When using DisplayPort (A) for the video input connection and the USB Type-C terminal (B) for the USB connection, set the KVM SWITCH 1 to DP Sync.
When using DisplayPort (A) for the video input connection and the USB Type-B terminal (B) for the USB connection, set the KVM SWITCH 2 to DP Sync.
When using the USB Type-C terminal (A) for the video input and USB connection, set the KVM SWITCH 1 to USB-C (DP Alt Mode) Sync.
When using the USB Type-C terminal (A) for the video input connection and the USB Type-B terminal (B) for the USB connection, set the KVM SWITCH 2 to USB-C (DP Alt Mode) Sync.
The monitor software update fails.
If the software update fails and an Update failed. Check the connection and try again error message appears on the INZONE Hub application, try the following:
- Check the connection and settings in the How to update the software of the monitor? section of this article.
- Disconnect the monitor's power cable and leave it disconnected for at least 1 minute, then reconnect it.
- Restart the computer.
- Try the software update again.
Note: This issue may occur if the computer is unstable, such as immediately after updating the Windows operating system.
Please accept Youtube cookies to watch this video
Access your cookie preferences below and make sure to switch on the Youtube cookie under the 'Functional' section.
Related Articles
Register your product
Get access to all information, keep your product up to date and enjoy great deals
Sony Community
Visit our Community and share your experiences and solutions with other Sony customers
Contact support
Contact your Sony Support team
Repair, Warranty & Spare Parts
Book, track or maybe even avoid a repair
