Article ID : 00280605 / Last Modified : 14/04/2026Print
    The settings (Equalizer, Spatial Sound etc.) on the INZONE Hub software do not work
    • To use the INZONE Hub software settings, make sure the Output of the computer is set to INZONE Buds-Game, INZONE H9 II / INZONE H9 / INZONE H7 / INZONE H5 - Game, or INZONE H6 Air / INZONE E9 / INZONE H3. Follow these steps to set the Output on the computer:
    • The App Sync Settings only works when the headphones are connected to a computer using the USB transceiver or USB Type-C® audio box and the INZONE Hub software is running.
    • The following function set using the INZONE Hub software will not work when the headphones are connected to PlayStation®5 or connected to any device via Bluetooth:
      • Sound Settings
        • Sound Profile
        • Equalizer
        • Spatial Sound
        • Spatial Sound Personalization
        • Dynamic Range Control
      • Microphone Settings
        • Microphone Volume
        • Auto Gain Control
        • Microphone Test
      • For INZONE H9 II only: The headphones have two types of equalizers: one that is enabled via INZONE Hub software, and one that is maintained on the headphones via the Sony | Sound Connect app. The equalizer is enabled according to the connection method as shown below.
        Connection method and the equalizer settings
        Connection methodApps that can set the equalizer functionWhere to save the equalizer settingsRemarks
        USB transceiver is set to PC *1INZONE HubINZONE Hub equalizer-
        USB transceiver is set to OTHER *1Sound ConnectMain unit equalizer
        • You can set the equalizer using the Sony | Sound Connect app only when the headphones are connected via Bluetooth.
        • The equalizer settings registered in the Sony | Sound Connect app are stored in the main unit and remain valid even when Bluetooth connection is not established.
        Bluetooth *2Sound ConnectMain unit equalizer-
        Headphone cable connected:
        Power is turned on / off
        Not supportedNot supported-
        *1 When a USB transceiver and Bluetooth function are connected simultaneously, the equalizer is activated in each path.
        *2 The equalizer does not work on call audio using the standard calling app installed in the initial version of the smartphone.
        Note: The main unit equalizer cannot be used when the USB transceiver is connected to a device other than a computer with the switch set to PC. When connecting to a device other than a computer, be sure to change the switch on the USB transceiver to OTHER.
