Article ID : 00230063 / Last Modified : 19/01/2026Print
How to take care of your Wireless Glass Speaker
    Cleaning your speaker
    When handling and cleaning your wireless glass speaker:
    • Carefully brush away dust with a soft brush or feather duster, and use the supplied cleaning cloth to clean the glass tube.
    • Use the supplied cleaning cloth to clean off fingerprints or oil marks from the glass tube.
    • If the glass tube is exceptionally dirty, clean it with a soft cloth dampened with lukewarm soapy water.
    • Don't disassemble your speaker. The glass tube is designed so that dust won't stick to its interior.
    • Don't use benzene, alcohol, thinner, detergent, etc. These chemicals will damage the surface finish of the speaker.
    Precautions
    • Don't grip the organic glass tube.
    • Avoid hitting or bumping the glass tube against other objects.
    • Don't splash water on any part of your speaker.
    • Do not use a scrubbing brush, sponge, use the supplied cloth.
