Sony | Sound Connect app: Support for Android 9 ending
Thank you for your continued interest in Sony products.
We would like to inform you that support for the Sony | Sound Connect app (previously known as Sony | Headphones Connect) on Android 9 will end in April 2025.
Consequently, certain Portable Music Players (Walkman®) will not receive updates for new versions of Sony | Sound Connect after April 2025, and features from these updates will be inaccessible. However, you can continue using the features currently available to you.
We apologise for any inconvenience and appreciate your understanding.
Applicable models
- NW-ZX500 series
- NW-A100 series
Functions no longer available
- You will not be able to install or update to new versions of Sony | Sound Connect after April 2025.
- You will not be able to use Sony | Sound Connect to connect with new products launched after April 2025.
