Article ID : 00401056 / Last Modified : 14/10/2026Print
    How to enable Menu timeout (Time to take action) on your Google TV™
    IMPORTANT: This article applies only to specific products and/or operating systems. Check the Applicable Products and Categories section of this article for details.
    The Quick Settings / Settings and Control menu will close after a short period of inactivity.
    If you need more time to read the menu and perform actions, you can extend the Menu timeout (Time to take action) by following the steps below.
    How to extend the Menu timeout
    1. The next steps will depend on your TV menu options:
      • Select Keyboard accessibility → Time to take action(accessibility timeout).
      • Select Time to take action(accessibility timeout).
      • Select Menu timeout → Extended 5 minutes.
