Article ID : 00401140 / Last Modified : 20/10/2026Print
    Enable Color correction on your Google TV
    IMPORTANT: This article applies only to specific products and/or operating systems. Check the Applicable Products and Categories section of this article for details.
    Color correction adjusts the screen colors on your Google TV™ to support users with different color-vision needs. The colors on the screen change based on the selected Color mode, which may improve the visibility and readability of text and images.
    To turn on color correction and select a color mode:
    1. On the remote control, press the Quick Settings (spanner or gear) button, then select Settings.
    2. Select Accessibility.
    3. Select Use Color correction.
    4. Select Enable and select Color mode options.
