This page introduces Frequently Asked Questions (FAQs) on Battery / Charging for REON 3 / 4 / 5 / PRO / PRO PLUS.
How long does the rechargeable battery of RNP-6T / 5 / 4 / 3 / P1 last?
How long is the continuous operation time when RNP-5 / 4 / 3 / P1 is powered by USB?
What USB AC adapter is recommended for charging?
Can I charge the battery with a mobile battery or a PC?
What kind of mobile battery do you suggest me to use?
What kind of AC adapter or mobile battery should I use to use fast charging?
When the charging cable is disconnected, the device will not operate. Is this a malfunction?
What kind of USB cable should I use when I use the device with USB power?
Can I purchase the charging cable that comes with the REON POCKET separately?
