ZV-1F: Initial setup and checking basic operation
It’s easy to set up the camera initially by pairing it with a smartphone over Bluetooth and using the Creators' App smartphone app.
Installing the app initially is convenient because once the settings are complete, you can transfer images to your smartphone and use it to control the camera remotely.
Download Creators' App to your smartphone.
For instructions on setting up the camera initially in Creators' App , see the following page.
Performing initial setup of the camera
Switching shooting modes
Each press of the Still/Movie/S&Q button (A) changes the shooting mode.
Icon Touch Function
By default, the Icon Touch Function is enabled for the camera. You can shoot, change settings, and perform other basic operations by tapping icons on the LCD screen.
Movie/S&Q shooting standby screen
- A: Icon Touch Function
- B: Creative Look
- C: Product Showcase Set
- D:
Self-timer
- E: Exposure Comp.
- F: Movie recording start/stop
- G: Zoom
- H: During playback/recording, this is an S1 (Shot Mark) icon
Still image shooting standby screen
- B: Creative Look
- D: Drive Mode
- E: Exposure Comp.
- F: Still image capture
- G: Movie recording start/stop
- H: Zoom
- I: Playback
- Besides controlling the camera by tapping icons or controls on the LCD screen, you can also focus and choose subjects by touch.
- For details on touch operations and the Icon Touch Function , refer to the Help Guide.
Function menu
The function menu contains frequently used menu items.
- Displaying the function menu
To access the function menu, while the shooting standby screen is displayed, press the Fn ( Function ) button (J) or swipe up on the LCD screen. - Selecting items
You can select items by pressing the top/bottom/left/right side of the control wheel (K) or by turning it. Items can also be selected by tapping the LCD screen.
- J: Fn ( Function ) button
- K: control wheel
You can also change the items in the function menu.
- To clean a smudged or dusty monitor, use a soft cloth or the like to gently remove any dust or debris on the surface before wiping away smudges. Be careful not to wipe the monitor too roughly with tissue paper or similar material, which may scratch it.
- Consider using a protective glass sheet that supports touch operations.
Product page for Screen Protect Glass Sheet PCK-LG1
All images used here are provided for illustrative purposes only.
