Article ID : 00288855 / Last Modified : 20/01/2026Print
    BRAVIA TV dimensions of Z9K series
    These dimensions are approximate values. For the dimensions when using the Sony Wall-Mount Bracket, refer to the Wall-Mount Bracket Installation Information on the product support website.
    Using a stand: Standard position
    TV dimensions labeled A through G
    Unit: millimetre
    Model (XR-, XRM-)A: screen widthB: screen heightC: stand widthD: height with standE: screen depthF: stand depthG: front stand depth
    85Z9K189610961895112476460201
    75Z9K1671971167099876396169
    Using a stand: Narrow position
    Unit: millimetre
    85Z9K18961096766114276460201
    75Z9K1671971576101776396169
    Using a stand: Sound bar position
    Unit: millimetre
    85Z9K189610961895119776460201
    75Z9K16719711670107276396169
    Mounting on a wall
    TV dimensions labeled from A through G
    Unit: millimetre
    Model (XR-, XRM-)A: screen widthB: screen heightC: wall-mount bracket hole distance (W)D: wall-mount bracket hole distance (H)E: bracket hole distance to side of screenF: bracket hole distance to top of screen
    85Z9K18961096400400748350
    75Z9K1671971300300686325
    • G: M6 holes for wall mount bracket
    • For screw length information, refer to the instruction manual.
    For product protection and safety reasons, Sony recommends that mounting your TV on the wall is done by Sony dealers or licensed contractors. Make sure you use the specified Wall-Mount Bracket. For details, refer to the TV manual.
