Article ID : 00288846 / Last Modified : 20/01/2026Print
    BRAVIA TV dimensions of A95K series
    These dimensions are approximate values. For the dimensions when using the Sony Wall-Mount Bracket, refer to the Wall-Mount Bracket Installation Information on the product support website.
    Using a stand: Front position style
    TV dimensions labeled A through G
    Unit: millimetre
    Model (XR-, XRM-)A: screen widthB: screen heightC: stand widthD: height with standE: screen depthF: stand depthG: front stand depth
    65A95K1444836144485176301282
    55A95K1225713122572875280265
    Using a stand: Back position style
    Unit: millimetre
    65A95K1444837144187754282203
    55A95K1225714122275354265194
    Mounting on a wall
    TV dimensions labeled from A through G
    Unit: millimetre
    Model (XR-, XRM-)A: screen widthB: screen heightC: wall-mount bracket hole distance (W)D: wall-mount bracket hole distance (H)E: bracket hole distance to side of screenF: bracket hole distance to top of screen
    65A95K1444836300300572422
    55A95K1225714300300463310
    • G: M6 holes for wall mount bracket
    • For screw length information, refer to the instruction manual.
    For product protection and safety reasons, Sony recommends that mounting your TV on the wall is done by Sony dealers or licensed contractors. Make sure you use the specified Wall-Mount Bracket. For details, refer to the TV manual.
