BRAVIA TV dimensions of A80K - A83K - A84K series
These dimensions are approximate values. For the dimensions when using the Sony Wall-Mount Bracket, refer to the Wall-Mount Bracket Installation Information on the product support website.
Using a stand: Standard position
Unit: millimetre
| Model (XR-, XRM-) | A: screen width | B: screen height | C: stand width | D: height with stand | E: screen depth | F: stand depth | G: front stand depth |
| 77A80K, 77A80xK, 77A83K, 77A84K | 1722 | 998 | 1409 | 1024 | 65 | 389 | 168 |
| 65A80K, 65A80xK, 65A83K, 65A84K | 1448 | 836 | 1184 | 862 | 64 | 330 | 142 |
| 55A80K, 55A80xK, 55A83K, 55A84K | 1227 | 712 | 1184 | 738 | 64 | 330 | 142 |
Using a stand: Narrow position
Unit: millimetre
| 77A80K, 77A80xK, 77A83K, 77A84K | 1722 | 998 | 619 | 1024 | 65 | 389 | 168 |
| 65A80K, 65A80xK, 65A83K, 65A84K | 1448 | 836 | 847 | 862 | 64 | 330 | 142 |
| 55A80K, 55A80xK, 55A83K, 55A84K | 1227 | 712 | 847 | 738 | 64 | 330 | 142 |
Using a stand: Sound bar position
Unit: millimetre
| 77A80K, 77A80xK, 77A83K, 77A84K | 1722 | 998 | 1409 | 1066 | 65 | 389 | 169 |
| 65A80K, 65A80xK, 65A83K, 65A84K | 1448 | 836 | 1184 | 904 | 64 | 330 | 143 |
| 55A80K, 55A80xK, 55A83K, 55A84K | 1227 | 712 | 1184 | 780 | 64 | 330 | 143 |
Mounting on a wall
Unit: millimetre
| Model (XR-, XRM-) | A: screen width | B: screen height | C: wall-mount bracket hole distance (W) | D: wall-mount bracket hole distance (H) | E: bracket hole distance to side of screen | F: bracket hole distance to top of screen |
| 77A80K, 77A80xK, 77A83K, 77A84K, 77A80K | 1722 | 998 | 300 | 300 | 711 | 579 |
| 65A80K, 65A80xK, 65A83K, 65A84K, 65A80K | 1448 | 836 | 300 | 300 | 574 | 416 |
| 55A80K, 55A80xK, 55A83K, 55A84K, 55A80K | 1227 | 712 | 300 | 300 | 464 | 292 |
- G: M6 holes for wall mount bracket
- For screw length information, refer to the instruction manual.
For product protection and safety reasons, Sony recommends that mounting your TV on the wall is done by Sony dealers or licensed contractors. Make sure you use the specified Wall-Mount Bracket. For details, refer to the TV manual.
