Article ID : 00288809 / Last Modified : 20/01/2026Print
BRAVIA TV dimensions of X85K - X89K - 85X80K series
    These dimensions are approximate values. For the dimensions when using the Sony Wall-Mount Bracket, refer to the Wall-Mount Bracket Installation Information on the product support website.
    Using a stand: Standard position
    TV dimensions labeled A through G
    Unit: millimetre
    Model (KD-, KM-)A: screen widthB: screen heightC: stand widthD: height with standE: screen depthF: stand depthG: front stand depth
    85X85K, 85X80xK, 85X80K, 85X85xK, 85X89xK,190110901532117886457184
    75X85K, 75X89K, 75X85xK16759621329104185412157
    65X85K, 65X89K, 65X85xK1452836120990682339133
    55X85K, 55X89K, 55X85xK1233711106178381339133
    50X85K, 50X89K, 50X85xK111964966571678288112
    43X85K, 43X85xK96456366562977288112
    Using a stand: Narrow position
    Unit: millimetre
    Model (KD-)A: screen widthB: screen heightC: stand widthD: height with standE: screen depthF: stand depthG: front stand depth
    85X85K19011090657117886457184
    75X85K1675962559104185412157
    65X85K145283647990682339133
    55X85K123371145878381339133
    Mounting on a wall
    TV dimensions labeled from A through G
    Unit: millimetre
    Model (KD-, KM-)A: screen widthB: screen heightC: wall-mount bracket hole distance (W)D: wall-mount bracket hole distance (H)E: bracket hole distance to side of screenF: bracket hole distance to top of screen
    85X85K, 85X80xK, 85X80K, 85X85xK, 85X89xK19011090400400751549
    75X85K, 75X89K, 75X85xK1675962300300688520
    65X85K, 65X89K, 65X85xK1452836300300576393
    55X85K, 55X89K, 55X85xK1233711300300467270
    50X85K, 50X89K, 50X85xK1119649200200460308
    43X85K, 43X85xK964563200200382222
    • G: M6 holes for wall mount bracket
    • For screw length information, refer to the instruction manual.
    For product protection and safety reasons, Sony recommends that mounting your TV on the wall is done by Sony dealers or licensed contractors. Make sure you use the specified Wall-Mount Bracket. For details, refer to the TV manual.
