Article ID : 00288800 / Last Modified : 20/01/2026Print
    BRAVIA TV dimensions of X80K - X81K - X82K series (43-75)
    These dimensions are approximate values. When using the Sony Wall-Mount Bracket, refer to the Wall-Mount Bracket Installation Information on the product support website.
    Using a stand: Standard position
    TV dimensions labeled A through G
    Unit: millimetre
    Model (KD-, KM-)A: screen widthB: screen heightC: stand widthD: height with standE: screen depthF: stand depthG: front stand depth
    75X80K, 75X80xK, 75X81K16759621329104185412157
    65X80K, 65X80xK, 65X81xK, 65X81K1452836120990682339133
    55X80K, 55X80xK, 55X81xK, 55X81K1233713106178381339133
    50X80K, 50X81xK, 50X81K111964966571678288112
    43X80K, 43X81xK96456366562977288112
    Using a stand: Narrow position
    Unit: millimetre
    Model (KD-)A: screen widthB: screen heightC: stand widthD: height with standE: screen depthF: stand depthG: front stand depth
    75X81K1675962559104185412157
    65X80K145283647990682339133
    55X80K123371345878381339133
    Using a stand: X82K series Standard position
    Unit: millimetre
    75X82K1675962623104085444182
    65X82K145283650990882325126
    55X82K123371351078581325127
    50X82K111964963171678303122
    43X82K96456363163077303122
    Mounting on a wall
    TV dimensions labeled from A through G
    Unit: millimetre
    Model (KD-, KM-)A: screen widthB: screen heightC: wall-mount bracket hole distance (W)D: wall-mount bracket hole distance (H)E: bracket hole distance to side of screenF: bracket hole distance to top of screen
    75X80K, 75X80xK, 75X81K, 75X82K1675962300300688520
    65X80K, 65X80xK, 65X81xK, 65X81K, 65X82K1452836300300576393
    55X80K, 55X80xK, 55X81xK, 55X81K, 55X82K1233713300300467270
    50X80K, 50X81xK, 50X81K, 50X82K1119649200200460308
    43X80K, 43X81xK, 43X82K964563200200382222
    • G: M6 holes for wall mount bracket
    • For screw length information, refer to the instruction manual.
    For product protection and safety reasons, Sony recommends that mounting your TV on the wall is done by Sony dealers or licensed contractors. Make sure you use the specified Wall-Mount Bracket. For details, refer to the TV manual.
